hazardpro
posted on 29/11/16 at 03:29 PM |
Zetec engine - clutch replacement
Hi all
I need to replace my clutch. Do you have to take out the engine to do so? :/
Zetec Black Top
Type 9 gearbox
Also I have no idea what clutch to replace it with as I don't know what the original donor car is :/ Can you tell what clutch you have ones you
remove it?
Doug
posted on 29/11/16 at 03:34 PM |
Yes, engine out as there's no room to drop the gearbox.
We will need to see a picture of the flywheel to determine standard 1.8 or 2.0 drilled for a pinto clutch etc etc...
hazardpro
posted on 29/11/16 at 03:51 PM |
Bugger!
Ok thanks So engine out, clutch off, post pics on here and hopefully someone can say what I need to order to replace!
Thanks.
Doug
posted on 29/11/16 at 04:55 PM |
Pictures of the flywheel, clutch and release bearing should do it!!!
