david cromie
| posted on 11/1/05 at 11:52 PM |
sva front setup
can anyone send me a picture of the front suspension set up for sva. a shot of the bubbers over the bolt heads etc. Nearly ready for sva.
alister667
| posted on 12/1/05 at 07:56 AM |
Hi David,
If you want I could pop round and have a look at it if that's of any help.
I work until 4:30 out at Newtonabbey, so I could pop round on my way home Mon-Thurs.
Let me know if that's of any help.
Glad to hear they've finally pulled their finger out and got you sorted with an SVA.
All the best
Ali
http://members.lycos.co.uk/alister667/
907
| posted on 12/1/05 at 08:34 AM |
I had a car pull up my drive a few days ago, ( another bl***y exhaust enquiry ).
One front wheel was heading for Colchester, the other was heading for Cambridge.
Oceans of camber, a footprint like a bicycle.
He said, " It self centres nicely "
It just didn't look safe.
Paul G
bob
| posted on 12/1/05 at 10:07 AM |
SVA covers and bits
Here is some stuff i did for my test and re-test.
bob
| posted on 12/1/05 at 10:09 AM |
shocks covered top and bottom
bob
| posted on 12/1/05 at 10:11 AM |
more shocks and edges including cycle wing
bob
| posted on 12/1/05 at 10:13 AM |
I also hade to file down the boot cover and remove and plug the key locks which i thought was a bit excesive.
bob
| posted on 12/1/05 at 10:17 AM |
Watch out for this one on the sierra handbrake,the handle needs covering at the back and you have to pull the handle/handgrip forwards to reduce the
button.
I didnt really understand this and like many of the points i argued about this
bob
And again
bob
| posted on 12/1/05 at 10:20 AM |
By the way the seats in the above pic were de-foamed in the base to achieve the correct harness upper anchorage height,i am still not convinced they
got it right but ho hum.
This is the dash and steering cover as well as the under dash radius cover.
alister667
| posted on 12/1/05 at 10:28 PM |
Bob (and David too!)
I was failed at Newtownards (Northern Ireland) by a tester (now thankfully moved onto a desk job since there were so many complaints about him!) for
not covering the tab on the track rod end (I've stuck a white arrow onto your pic Bob so you can see).
I had to cover it up.
Funny enough it fell off soon afterwards.
Ali
He also failed me because I could not remove the covering over the track extension locking nut so he could check it was tight - I'd used
sikaflex to hold the cover on.
If I ever see him in the road, I ain't braking.....
