Kev99
| posted on 15/1/05 at 08:35 PM |
Rear Stub Shafts
The rear stub shafts do not fit it the hub carrriers supplied by MK (Rear Disc) .Has anyone had this problem if so how much did thay m/c off the stub
shaft dia and depth?
| posted on 15/1/05 at 09:47 PM |
It's a common problem - remedied by machining the ABS Ring off. Normally down to just below the serrated tooth diameter is enough. They are
aware of the problem and it doesn't occur when drum's are fitted.
HTH
Benzine
| posted on 15/1/05 at 09:55 PM |
I had ABS rings and removed them as hellfire said:
Kev99
| posted on 15/1/05 at 10:04 PM |
I will do that at work on monday then thanks. So I only need to go as far back as abs ringsas well as remove them dia wise
| posted on 15/1/05 at 10:34 PM |
We machined the lot off, producing an unstepped diameter Kev - lightening it even further
