trueblue
| posted on 21/1/05 at 08:12 PM |
mk wishbones
Has anybody any dimensions of mk wishbones?
Im interested in how they compare to
standard book ones.
Trueblue
Dick Axtell
| posted on 21/1/05 at 08:19 PM |
Locost w/bones, (live axle rear, front- Cortina uprights), or the Indy type, (2xw/bone rear, front- Sierra uprights)?
[Edited on 21/1/05 by Dick Axtell]
Dick Axtell
| posted on 21/1/05 at 08:29 PM |
MK Wishbones
My early type MK 'bones have the mounting bush sleeves set at 352mm, whereas the book dimension is 343mm.
See next post for pic comparison.
Dick Axtell
| posted on 21/1/05 at 08:37 PM |
Luego vs. MK early
Following pic shows Luego type on the left, MK early (non-Indy) type on right.
Luego is fairly close to book drg.
dblissett
| posted on 21/1/05 at 09:22 PM |
tube size
what diameter are the wishbone tubes the leugo ones look to be a larger diameter
the reason i ask is there was a thread about wishbones bending at the point where the shock plate and whishbone meet
the conclusion seemed to be the shape of the plate (sharp corner ) concentrated the load on the wishbone tube and either a larger diameter whishbone
tube or a better shock plate design (with a gradual taper to spead the load) was better
cheers dave
RoadkillUK
| posted on 22/1/05 at 02:54 PM |
Hey, that's my floor !!
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
zetec
| posted on 22/1/05 at 04:42 PM |
Have you changed the Indy ones also?
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
dblissett
| posted on 22/1/05 at 07:41 PM |
wishbones
snoopy how long have you been doing them like that they look much better (stronger) and is that oval tube?
how much are they per pair
cheers dave
ReMan
| posted on 22/1/05 at 10:48 PM |
quote: Originally posted by snoopy
the locost ones have been like this quite awhile yes there oval and same price as before
as to indy tops then yes due to market forces we are jiging up with some designs in oval
Do you have a timescale for this jigging?
www.plusnine.co.uk
