New Topic New Reply
Author: Subject: Exhaust hole surround
shortie
posted on 1/2/05 at 11:35 AM Reply With Quote
Cut the hole in the side panel for my exhaust last night, a bit scary but turned out nice. Drilled four holes in the corners and then used the Dremel, came up a treat.
I want to put an ali surround on the hole and woould like to find out how much it would be to get this laser cut so that it is nice and accurate.
Does anyone know where I could get this done or how much it is likely to be?
ta,
Rich.
posted on 1/2/05 at 12:22 PM Reply With Quote
Lolocost sell them
shortie
posted on 1/2/05 at 12:29 PM Reply With Quote
Yeah but it needs to be a specific shape, basically I want someone I can give the shape to and they will laser cut it out of ally
colibriman
posted on 1/2/05 at 12:47 PM Reply With Quote
I might be able to sort that out for you Rich,
email me the template ?
Maeantime I'll work out a cost, shouldn't be expensive..
need a bike engine? - www.colibriman.com
SVA ready Mk Indyblade possibly for sale.....if the offers good...!
shortie
posted on 1/2/05 at 01:03 PM Reply With Quote
Thanks,
Will draw up the template and email it, any particular format or just so it shows the dimensions?
Rich.
colibriman
posted on 1/2/05 at 01:09 PM Reply With Quote
really just draw it exactly as you want it - full size...dimensions may help too, just to be sure.
how thick would you want it?
shortie
posted on 1/2/05 at 02:21 PM Reply With Quote
No problem, will email tonight, it's info@colibriman.com isn't it?
I reckon 3mm should do the trick, I was thinking of having two, one either side so as to act as a bit of a heat sink and protect the fibreglass.
Rich.
zetec
posted on 1/2/05 at 06:06 PM Reply With Quote
Let me know how it turns out, i might have one if the price is not tooo much.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
colibriman
posted on 1/2/05 at 11:19 PM Reply With Quote
Hi Rich,
that email address will be fine.
Colin
Guinness
posted on 2/2/05 at 07:12 AM Reply With Quote
I have access to a 8'x4' CNC flat bed punch, which although not quite as neat as a laser can cut shapes and holes in stainless (up to 3mm) and aluminium (up to 5mm).
Cheers Mike
colibriman
posted on 2/2/05 at 10:11 AM Reply With Quote
Mike,
I'm initially going to get a fireblade one priced up - I want 2 of these also....I would get these done on a CNC milling machine.
See what price you can sort out using the CNC Punch - It would be good to have another option.
Colin
New Topic New Reply
