New Topic New Reply
Author: Subject: indyblade cooling micra rad
tim windmill
posted on 15/3/05 at 09:44 AM Reply With Quote
trying to sort out cooling system for 929 blade with micra rad.25mm hose from water pump direct to bottom of rad. 25mm hose from thermostat housing to top of rad. smaller house from thermostat i suspect goes into a non pressurised expansion tank entering at the bottom. rad has a presurised cap and an outlet on the neck does this also go to the expansion tank entering at the bottom or can it be blanked off.i have read on previous threads about a 'T' piece being required if so is this for the smaller hose from the thermostat into the top hose and not going to the expansion tank as originally thought. hope somebody understands this as i have confused myself writing it.
shortie
posted on 15/3/05 at 09:47 AM Reply With Quote
Tim,
Hopefully this might help....
Rich.
ReMan
See "watersys" pic in Snoopys photo archive, thats the way I did it.
I also got MK to make me the lower water rail out of metal tube, so it fixes to chassis bottom rail= neat.
ChrisGamlin
posted on 17/3/05 at 01:47 PM Reply With Quote
I should have put Copyright on the bottom of that diagram shouldnt I
That one is for the pre-98 engine, I have another one at home for the 98/99 engine if its more relevent
Chris
shortie
posted on 17/3/05 at 02:41 PM Reply With Quote
yeah Chris, excellent diagram, you'd have made a fiar bit of cash now with a copyright
New Topic New Reply
