mad-butcher
| posted on 13/4/05 at 06:05 PM |
what size battery for indy blade
evening all, what size batter do i need for a blade powered indy i know the standard honda one is 12v8ah do i need a bigger one of say 40ah
many thanks
tony
Wadders
| posted on 13/4/05 at 06:11 PM |
i have a 14ah bike battery on mine, but when you think about it, a bec shouldn't need any more juice than a bike, unless you want to run a
heater or an electric reverse etc. I would guess that a standard blade one should be fine. Try it and see, its not an expensive mistake if you need to
up the size later.
Al
many thanks
tony
OX
| posted on 13/4/05 at 06:35 PM |
yip i would also go for the 14ah
i'd get either a yausa or varta sealed battery ,they cost a little more but well worth it
shortie
| posted on 13/4/05 at 07:24 PM |
yep, me too, yuasa
ChrisGamlin
| posted on 14/4/05 at 08:49 AM |
I ran a YTX9BS (same as blade bike) on mine, it was OK but could probably do with a bit more juice on occasions so a 12-14Ah like the others have
recommended sounds about right.
Give MDS Battery a call, one of the guys there Mike Field runs in RGB so if you tell them youve got a BEC and
mention the Yahoo BEC list they'll usually give you a bit of discount.
Chris
ChrisGamlin
| posted on 16/4/05 at 11:04 AM |
Thats an additional 5kg which equals a good 12bhp/ton decrease on the pub bragging rights
