ChrisGamlin
| posted on 14/4/05 at 08:50 AM |
MK Bonnet scoop
Does anyone have any dimensions for the MK bonnet scoop handy please?
cheers
Chris
Humbug
| posted on 14/4/05 at 11:20 AM |
I spoke to MK a while ago and they gave me approximate dimensions of 20" long x 20" wide x 2" high (max). Worth checking, though
Also, kingr has a picture of his car with the MK scoop on: Imgp0397shrunk.jpg
locoboy
| posted on 14/4/05 at 12:25 PM |
it certainly looks to be squareish on this piccy i have of one
  indy dash
[Edited on 14/4/05 by locoboy]
[Edited on 18/4/05 by locoboy]
Locoboy
ChrisGamlin
| posted on 14/4/05 at 04:27 PM |
Thanks for the info
Does it bend much to fit the curvature of the bonnet, from here that one in the pic looks like its got a bit of a gap round the outer edges?
Crazy Jay
| posted on 14/4/05 at 11:46 PM |
My scoop came with the boneet and is a really nice job. Measured the scoop earlier for you but 4got to post
[img][/img]
locoboy
| posted on 15/4/05 at 11:05 AM |
Chris,
This was a really nicely finished indy made by a mate of mine - attention to detail is his thing..................believe me there would have been no
gap around the edge!
Locoboy
ChrisGamlin
| posted on 15/4/05 at 07:20 PM |
Thanks for the measurements, i think the "gap" must be a trick of the light in that pic maybe, does look a very nice build, 10x tidier
than my car
Also, how much internal clearance does it give you, is the 2" mentioned above fairly constant along the main section?
locoboy
| posted on 15/4/05 at 10:15 PM |
you can rest assured it must be the light playnig tricks on you!
I dont know about the clearance on the scoop, in all fairness when he had the bonnet off the last thing on my mind was to go and take a look at the
underside of the bonnet, i was too busy going WOW at the standard of the build under it!
The dash edgng is vinyl covered wood, as are the door tops and he covered the centre of the steering wheel in blue vinyl himself too
Locoboy
ChrisGamlin
| posted on 16/4/05 at 11:01 AM |
Cheers Col, I wasnt questioning the fit n finish on the car, I was just a bit concerned that the scoop rear edge might be quite rigid and so might not
bend round to fit the profile of my bonnet
