Avoneer
| posted on 12/5/05 at 09:53 PM |
Bit of bending at MK
Was at MK this morning getting some tubes bent and even though I'm not building an MK, it didn't make any difference.
Tubes bent spot on 1st time and exactly how I wanted them.
Great all round service...
Just though I'd share that with everyone.
Pat...
| posted on 12/5/05 at 10:11 PM |
I'd expect nothing less of MK (Engineering or Sportscars)... great blokes, great quality of work with good pricing to boot!
Do you have any pictures Pat?
[Edited on 12-5-05 by Hellfire]
Avoneer
| posted on 12/5/05 at 10:16 PM |
Yep, nut it didn't come out too well.
It's the top and bottom tubes on the very rear of the tub.
Also using MK pedals and a few other bits.
Pat...
scoobyis2cool
| posted on 12/5/05 at 11:45 PM |
Blimey, you didn't hang about getting them welded on did you! Looking good
Pete
niceperson709
| posted on 13/5/05 at 12:58 AM |
Hi pat just thought i would show you a picture of what i did to make the full weld of my chasis easier I tacked some tabs on the front of my frame so
that I could attach it to an engine stand and a tab at the back to hold it to a tresle it was then posible to rotate the frame as I welded it up . I
" danced " arround the frame to avoid distortion as I welded it up . this worked a treat and also ment that I did not have to do welds at
difficult angles , worth considering any way .
best wishes
Iain [pg=]
Best wishes IAIN
life is not the rehearsal , it's the show so don't sit there thinking about it DO IT NOW
http://iainseven.wordpress.com/
niceperson709
| posted on 13/5/05 at 01:02 AM |
I ment to use this photo [pg=]
Best wishes IAIN
Avoneer
| posted on 13/5/05 at 06:48 AM |
Cheers Iain - top idea, but my friend is going to weld it up for me at his works on one of there big flat jigs.
Oh yes, forgot to mentionen my big 3mm plate that MK sheared into manageable langths for me..... (Is that OK snoopy)?
Pat
niceperson709
| posted on 13/5/05 at 06:54 AM |
" but my friend is going to weld it up for me at his works on one of there big flat jigs."
Hi Pat that is very lucky for you then
Best wishes
Iain
Best wishes IAIN
andyps
| posted on 13/5/05 at 09:49 AM |
Iain, how did you make sure it stayed true whilst welding it like that?
