New Topic New Reply
Author: Subject: Aluminium Tube for cooling
shortie
posted on 7/6/05 at 11:34 AM Reply With Quote
I need to get a lower tube made up in 1inch aluminium tube with a 10mm T-piece for the cooling system on my Indyblade.
Does anyone know could knock this up for me.
Rich.
ned
posted on 7/6/05 at 11:35 AM Reply With Quote
allyfab....
Ned.
beware, I've got yellow skin
Jeffers_S13
posted on 7/6/05 at 11:36 AM Reply With Quote
You can make it yourself then get a fab place to weld it up. Ive made lots of ali bits and modified things to suit, then I found a fabrication place nearby.
jimgiblett
posted on 7/6/05 at 12:56 PM Reply With Quote
Hi Rich,
As Jeffers says make it yourself and get a fabricator to TIG it up. I used Exactweld(GB) Ltd of East Grinstread to TIG weld my radiator. Nice guys and very reasonable prices.
Tel No is 01342 311595
Jim
MAB
posted on 7/6/05 at 01:18 PM Reply With Quote
Mine is an MK steel one they welded up whilst I was there. If I recall, they only charged me a fiver for everthing (although I was getting other stuff aswell). If you are going to Newark, maybe they could bring you one down?
The weight difference is negligible and sprayed black matches the power coated chasis.
Regards Mark.
shortie
posted on 7/6/05 at 01:32 PM Reply With Quote
Have decided to make it from copper complete with beeding at each end courtesy of the compression fitting and then paint it silver, very locost
[Edited on 7/6/05 by shortie]
New Topic New Reply
