sturead77
| posted on 12/6/05 at 06:18 PM |
Rear caliper brake lines?
Have just fitted the flexis to my rear brake calipers and found to my horror that the solid end portions on the flexis are so long that they foul the
inside of the wheel rims.
Can anyone tell me whether or not i can get away with running a small length of copper pipe out of my rear calipers, through a bracket on the rear
upright and then into a flexi?
I know this is the way it is normally done on drum brake rears as the rear piston assy is not going to move around but i have never seen it done on
rear calipers.
mookaloid
| posted on 12/6/05 at 06:58 PM |
What size wheels are you using?
I didn't have this problem
Cheers Mark
sturead77
| posted on 12/6/05 at 07:02 PM |
I'm using 15" rims as suggested in the build manual with standard ford calipers. Can't work out where i'm going wrong!
mad-butcher
| posted on 12/6/05 at 07:59 PM |
never had that problem either.(don't know the answer to my question) but is it possible to put the calipers on upside down or back to front. any
chance of a picture. what offset are the wheels
tony
mad-butcher
| posted on 12/6/05 at 08:06 PM |
i've routed mine a different way
mookaloid
| posted on 12/6/05 at 10:53 PM |
That looks the same as mine
Mark
[Edited on 12/6/05 by mookaloid]
sturead77
| posted on 13/6/05 at 05:31 AM |
Thanks fellas
I'll give that set up a bash and see what happens
Cheers for your help
