New Topic New Reply
Author: Subject: cooling problems
mad-butcher
posted on 30/6/05 at 06:26 PM Reply With Quote
cooling problems
2 lt pinto on twin webbers volvo header tank and mk radiator...
problem is I'm getting one hell of a pressure build up and it's driving me round the twist. I've got it piped up small overflow pipe on radiator to header tank large pipe on water pump tp bottom of radiator smaller pipe to header tank ( I think it was used for heater). thermostat hosing large pipe to top of radiator very small pipe blanked off water pipe on inlet manifold blanked off (again I think this was heater) with engine running and no cap on header tank the tank just overflows till system is empty with cap on it tries to blow the pipe to header tank from pump off
any one any ideas is it worth losing the thermostat
many thanks
tony
mad-butcher
posted on 30/6/05 at 07:38 PM Reply With Quote
seems to be .no oil in water, no water in oil
tony
Danozeman
posted on 30/6/05 at 07:47 PM Reply With Quote
Water pump?
The head gasket can still be gone even if theres no fluid mixing.
Dan
Dusty
posted on 30/6/05 at 10:00 PM Reply With Quote
I had similar problem last year with the engine blowing all the water out when driven fast. Changed water pump, ran without stat, had three row rad made up and changed the head gasket. Had the head checked for porosity and it was fine and while it was at the engineers asked him to skim it to make sure it was flat. It wasn't!. Never saw any bubbles in the rad or water in oil or vice versa. Clue was that the temp gauge didn't show it overheating, it just blew the water out.
Ran fine for another 2000 miles and lost all the water on the motorway coming back from Newark a couple of weeks ago. Took a while to find in the half light by the side of the road but the water pump bolts had loosened off till the water fell out. Tightened them up, refilled and all was well. Locktite and spring washers now fitted.
New Topic New Reply
