welderman
posted on 1/8/05 at 09:44 PM |
Sierra Diff question
Are all bolt on shafts LSD or can some bolt on ones be non LSD?.
posted on 1/8/05 at 09:45 PM |
nope, but all standard LSDs are lobro (bolt-on)
some bolt on diffs are open, in case that wasnt clear!
[Edited on 1/8/05 by JoelP]
Benzine
posted on 1/8/05 at 09:48 PM |
Mine is lobro and non LSD
welderman
posted on 1/8/05 at 09:50 PM |
Thanks for that. Need to find out if it has a tag then do i.
Ta .
mad-butcher
posted on 2/8/05 at 05:28 PM |
the serial numbers cast on the case will also give you what type and ratio i think its 2 A's is lsd 314 is 3.14 ratio. i've seen a posting
somewere but can't remember
tony
posted on 2/8/05 at 06:18 PM |
the AA and the 362 are written on the tag on the back cover, not sure if its written elsewhere on the diff? never seen it anywhere else anyway.
