New Topic New Reply
Author: Subject: Cortina front uprights on an Indy
the_fbi
posted on 19/8/05 at 08:33 PM Reply With Quote
As I understand it, the Indy wishbone setup is designed for Sierra (modified by MK) front uprights, can the Cortina (Mk5) uprights be substituted with no modifications or are different wishbones/balljoints required?
If the Cortina stuff can be used I presume MK knock the modification price (of the Sierra uprights) off the kit price?
ta
Chris
posted on 19/8/05 at 08:42 PM Reply With Quote
No - Cortina uprights can't be used with Indy wishbones. The geometry is quite different between the Cortina and Sierra hubs. The MK mod to the Sierra hubs is to re-drill the bottom ball joint tapered hole to suit the Maxi ball joint which MK have designed into the wishbone/car.
Is there a reason you would want to use Cortina uprights?
If you have a pair of Cortina uprights and you want to build an Indy, sell the uprights for the good money they are worth and use cheap as chips Sierra hubs.
HTH
Nick
the_fbi
posted on 19/8/05 at 09:16 PM Reply With Quote
I read somewhere on here that the Cortina geometry was better than the Sierras, and thought this was on an Indy
They are substantially lighter than the Sierra ones, also more compact and nicer looking.
Guess I'm going to have to. And I'd planned to spend the weekend rebuilding them too, bummer.....
Thanks.
Chris
posted on 19/8/05 at 09:24 PM Reply With Quote
I don't know how the geometry compares, but the Indy is obviously designed for the Sierra uprights. The good thing is you probably won't need to overhaul a pair of Sierra hubs other then tidying up the calipers.
As a bonus, the money (~£70-100) you'll get for the Cortina uprights would pay for a nice set of grooved discs to go on the Sierra hubs
Nick
ned
posted on 19/8/05 at 09:40 PM Reply With Quote
or of course use the uprights you have and buy a locost chassis from mk (quite similar to the indy) ask them to make it suitable for a dedion rear axle so you can use a sierra dif and rear end, I'm sure they'd be willing to sort something out for you!
Ned.
beware, I've got yellow skin
New Topic New Reply
