Apoorman
posted on 12/1/03 at 06:37 PM |
indyblade missfire
Hi Everyone! Can anyone throw any light on why my recently built indy blade missfires at high revs if the bike airbox is removed and replaced by a
smaller one ( so the bonnet will fit ) i'm told it needs ' flat slides ' in the carbs, any info very welcome. Ta.
jollygreengiant
| posted on 12/1/03 at 08:29 PM |
probably due to air flow turbulence through the carb/injector body (you didn't specify which but most likely anyway).
Enjoy.
locodude
| posted on 12/1/03 at 08:31 PM |
Hi
TTS do a jet and filter kit specifically to allow a blade engine to fit under kit-car bonnets which includes a pipercross filter. I think one or two
guys on the list have fitted it so it must do the job.
Jon Ison
| posted on 12/1/03 at 08:49 PM |
Hi, home made air box, thin ally sheet then used blade filter element, works a treat n fits under bonnet like a glove..........
Apoorman
| posted on 14/1/03 at 08:02 PM |
Thanks, I'll ring TTS.
