ReMan
| posted on 2/9/05 at 06:03 PM |
Pedal stops
I need to make some BACK stops for my throttle and clutch pedals. ie to stop me breaking the cable when I press the pedals hard. I've seen nuts
and bolts screwed into the footwell but wondered if anyones achieved something more elegant, i'm looking for inspiration
www.plusnine.co.uk
antonyg
| posted on 2/9/05 at 06:17 PM |
Hi, i was thinking about welding some sort of adjustable stop to the back of the pedals with a rubber foot on the ends so that it hits one of the
chassis rails in the footwell when the pedal is pressed.
just an idea, am sure others have done something different/better
Antony
OX
| posted on 2/9/05 at 06:32 PM |
yeah i did the bolt thing with the r1 and didnt like the look ,this time i copied how shed did his and used a little bit of alloy angle bolted to the
floor,it isnt that big and doesnt get in the way .im no picasso but hope the piccy helps
[img][/img]
ReMan
| posted on 3/9/05 at 10:45 AM |
I suppose I should have posted this pic first as I did'nt explain very well. As you can see in this picture of someones (Westfield I think))
pedals, I need to put somerthing behind my MK pedals to stop me snapping the cable or breaking the carbs if I press to hard.
This looks oK from the footwell as you cant see them , but i'm not too keen on big bolt threads sticking into the engine bay, from a purely
cosmetic point of view......
www.plusnine.co.uk
OX
| posted on 3/9/05 at 11:39 AM |
no m8 you explained ok but may be i didnt ,the alloy will stop the pedal going as far as you want it , the top pedal moves forward and the bottom part
of the pedal hits the alloy as it swings towards you
