New Topic New Reply
Author: Subject: fuel tank vent
mkblade
posted on 22/9/05 at 10:12 PM Reply With Quote
fuel tank vent
im stripping out my tank ,at weekend i drilled a hole in the top of tank put a small peice of pipe in it and run a length of hose as the breather to stop the tank walls being sucked in.
what has everyone eles used ,should i leave it open to noral air,or put some time of one way valve in it .
thanks
simon
posted on 22/9/05 at 10:16 PM Reply With Quote
Just use a long piece of hose and bend it in a loop at the top so its pointing downwards somewhere near the bottom of the tank. Personally I would leave it vented to atmosphere but others prefer to put a valve in the end. Choice is yours really
zetec
posted on 22/9/05 at 11:35 PM Reply With Quote
Try and get a motorbike tank vent valve, couple of quid, then means no chance of spillage. I was surprised how much the fuel is "pushed" to the end of the tank in fast corners. If you have a full tank there is a chance of fuel spilling, happened to me at Brands on a trackday.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
mark chandler
posted on 23/9/05 at 12:08 PM Reply With Quote
MSA regs call for a one way valve for competition, just bung a servo valve on the end of the tube, zero cost as you will not be using the servo from your donor.
Regards Mark
New Topic New Reply
