New Topic New Reply
Author: Subject: brake query
zxrlocost
posted on 22/11/05 at 01:25 PM Reply With Quote
brake query
afternoon
what method/bits has been used to make the brake pedal lever bar that goes into the master cylinder from the pedal and does the cylinder just bolt directly to the chassis and line up in the middle of the hole, obviously looks that way but best to 100% check
ie the fork and the bar and anyother little bits..
thanks chris
zxrlocost
posted on 22/11/05 at 01:27 PM Reply With Quote
Ox did tell me over the phone so I got a basic picture.(cheers for any help mate)
but I dont seem to have any pics out of all the zillions I took theres none of the brake pedal
mike smith1
posted on 22/11/05 at 01:35 PM Reply With Quote
If you look in my photo archive at the pic called pedals u can see the clevis, and into the master cylinder i made a push rod from some ht threaded rod with the end rounded over, dunno if this will help
Mike
mike smith1
posted on 22/11/05 at 01:37 PM Reply With Quote
I drilled mine at 60mm centre to centre as snoopy said.
zxrlocost
posted on 22/11/05 at 02:10 PM Reply With Quote
ok cheers
New Topic New Reply
