New Topic New Reply
Author: Subject: New builder in norfolk
tricky262000
posted on 3/12/05 at 08:36 AM Reply With Quote
I have just started on my indy build with pinto power, would like to know if anybody else has build an indy in this part of the country.
Does any know what the best throttle linkage is for 38 dgas on a sierra monifold is?
donut
posted on 3/12/05 at 09:04 AM Reply With Quote
Hi there and welcome to the daftest place on the interweb!
There are a few people from your area, one of which is skidmark on this forum and he's from Attleborough.
I don't know the answer to your cable question but alot of people use bicycle brake cables!
mookaloid
posted on 3/12/05 at 09:40 AM Reply With Quote
Welcome, I would imagine that the linkage from the 3.0 Capri would do the trick - that's where the carb came from after all.
Mark
Danozeman
posted on 3/12/05 at 10:15 AM Reply With Quote
Welcome mate. Im just down the road in Suffolk. Theres s few norfolk pepole on here.
Piddy is in Thetford.
Dan
piddy
posted on 3/12/05 at 01:42 PM Reply With Quote
Hi. Tricky.
Welcome to this group.
I'm Piddy from Thetford. Not building an Mk but a Luego velocity on a similair theme.
Youll find that the Dgas uses a Cortina or Capri linkage and cable.
Are you sure it will fit on a Sierra manifold?
If it doe's then it must be from an early one which is the same as a Cortina/Capri.
piddy
posted on 3/12/05 at 01:43 PM Reply With Quote
Meant to ask where in Norfolk are you from?
Taz Surfleet
posted on 3/12/05 at 03:05 PM Reply With Quote
greetings from norwich
jonbeedle
posted on 3/12/05 at 03:27 PM Reply With Quote
Greetings from Lakenheath Suffolk!
Jon
"Everyone is entitled to an opinion however stupid!"
posted on 3/12/05 at 05:09 PM Reply With Quote
38dgas
I don't think it does, if I remember we had to oval the holes to fit one on a friend's car. I think there is a Cortina to Pinto manifold that fits it but they are scarce.
piddy
posted on 3/12/05 at 07:18 PM Reply With Quote
As I said earlier the very first Sierras had the same inlet manifold as the Cortina/Capri.
Cortina/Capri manifolds can be found on E bay,ever now and then.
New Topic New Reply
