mike smith1
| posted on 13/1/06 at 09:33 AM |
Fitting Panels
We are going to start fitting the panels this weekend, any hint and tips??
Was going to hinge the nose cone, i have a piano style hinge, was wondering how others had done it?
I understand the order is:
Nose Cone
Scuttle ( lined up were bonnet falls)
Side Panels
Rear Panel
Any Other orders that have been found easier etc
Many Thanks Mike
zxrlocost
| posted on 13/1/06 at 09:36 AM |
alright mike
make sure you lay the scuttle bonnet and nose out first to make sure its all in line
and remember what I was told about doing to the back panel meets side panel that I then told you ie spacing it out a bit
chris
mike smith1
| posted on 13/1/06 at 09:40 AM |
Is that packing it above the rear shock with some ali, to make it meet up??
Any news from Savage Mate?
Cheers Mike
| posted on 13/1/06 at 09:48 AM |
For what it's worth I fitted the side panels first, then located the scuttle using the point where the side panels start to narrow towards the
front of the car. Then I taped the bonnet in position and used this to get a position for the nose cone. I didn't hinge the nose cone as my
rad was a very tight fit and wouldn't have allowed the nose to roll forward, but it would be a neat feature.
I still have the rear panel to fit when I work out what to do with the join between it and the side panels.
Best advice I can give is work slowly and carefully
HTH
Nick
zxrlocost
| posted on 13/1/06 at 09:51 AM |
no news from them mate as said before I will send it as soon as it comes but as in message it will be the end of next week
they dont rush for no one
yes above rear shock right at top of chassis put something decent width aswel in there about 4mm thick as when you put the side panels on they sit ok
at the back but when you try to fit the back panel its such a poor fit you have to get two people to push each side in and its under so much stress
so two 4mm thick spacers each side OTB will help it a bit
obviously the very end of the side panel and start of the back panel will slightly be sticking out a bit but it looks perfect when its all
together
hth chris
RazMan
| posted on 13/1/06 at 11:11 AM |
The best tool I ever used for panel fitting is the Cleko
Raz
mike smith1
| posted on 13/1/06 at 11:58 AM |
quote: Originally posted by nick205 Best advice I can give is work slowly and carefully
HTH
Nick
It will definatly be slowly want to get it to look right, dont want to mess up!
Cheers Mike
mike smith1
| posted on 13/1/06 at 02:16 PM |
Will do Mr Snoopy! Do you fancy coming to fit them! lol
Any other tips Charlie? I know you are the expert!
Mike
[Edited on 13/1/06 by mike smith1]
Bluemoon
| posted on 13/1/06 at 02:22 PM |
Don't want to hijac the thread, but how to you know where to put the Scuttle if you place it first? I ask as I am making an Ali bonnet, and side
pannels it's even more importent to know exactly were to put it...
Taz Surfleet
| posted on 13/1/06 at 02:46 PM |
front of scuttle will only fit in one place to the top of footwells, then attach scuttle to it !
Bluemoon
| posted on 13/1/06 at 05:06 PM |
Sorry, dim moment, it's wedge shaped, so it should be simple.. Only problem I have is how long is a standard MK bonnet, any idea? Then I can get
the nose in the correct place for an MK bonnet if I chicken out of making it....
indykid
| posted on 13/1/06 at 05:12 PM |
i don't want to cause any offence snoopy, but if you put the battery panel on first, and use that to gauge where the scuttle goes, it'll end
up looking a real dogs dinner.
the battery panel is too long in the horizontal section, such that when it is butted up against the tubes at the top of the footwells, it puts the
rear tips of the scuttle well past the apex of the side panels. to get a proper fit, it needs to be brought forward about 3/4", maybe even the
full inch so the rear tips of the scuttle sit bang on the apex of the side panels. also, once the side panels are on, the batt tray needs trimming on
the sides of the horizontal surface so that it sits within the side panels, allowing the bonnet to sit flush on the side panels. it's not a tiger
after all
the order then, imho:
-side panels dry fitted, well taped up
-back panel dry fitted and trimmed to meet side panels
-sit scuttle on so rear edge is inline with the kink in the side panel
-mark the scuttle and side panel for 2/3 rivnuts either side for bolting scuttle on
-battery tray on, butted up to the scuttle, and mark underside for holes to fasten into footwell top tubes
-nose cone on, with bonnet sat ontop loosely to get alignment.
as for hinging it, i used some stainless fire door hinges, because they looked the part, and were stainless, but given the chance to do it again,
which i soon will, i'd fasten one half of the hinge to the vertical flange inside the nosecone, and the other to the underside of the front lower
tube. currrently, they're fitted between the front face of the lower tube, and to the sloping face of the nosecone, with a s/s reinforcing plate.
they're a real pita to set up, and it spaces the nosecone away from the chassis, which makes alignment awkward.
hth
tom
mike smith1
| posted on 13/1/06 at 08:03 PM |
Cheers for the advice indykid, will bear that in mind mate.
Cheers Mike
mike smith1
| posted on 24/1/06 at 09:19 AM |
Anyone got any pictures of fitting the back panel and how it meets the side panels, and also the cutting out if the roll bar has back stays, also my
roll bar is welded on so does this make any difference? and any tips on fitting it!
Cheers Mike
[Edited on 24/1/06 by mike smith1]
cryoman1965
| posted on 24/1/06 at 09:45 AM |
I hope yours fit better than mine, or do they all fit this well.
mike smith1
| posted on 24/1/06 at 01:02 PM |
I have only offered it up at the minute and looks like i'm going to have to trim out a lot for the roll bar becuase it is welded in any pics
appreciated!
Thanks Mike
