kev R1
| posted on 29/1/06 at 07:22 PM |
mk indyR1
two things here, firstly i buugered my fuel guage up today any recomendations for a new one?
and as you can see in this pic i've put my exhaust on and it does'nt seem to hang right seems to catch the bodywork at the front and seems
to be quite a way off at the back, have i got it wrong or something, one plus factor is it's amzingly loud!!
kev R1
| posted on 29/1/06 at 07:23 PM |
fesycresy
| posted on 29/1/06 at 07:25 PM |
The link pipe looks wrong.
Are you sure it's the right one ?
kev R1
| posted on 29/1/06 at 07:30 PM |
not too sure just the one that came with it.
fesycresy
| posted on 29/1/06 at 07:34 PM |
Did you buy it from MK ?
mandbsheldon
| posted on 29/1/06 at 07:43 PM |
Kev, hope you don't mind if I point out, that battery dosn't seem to fit right either
My pipe was exactly the same, buy Phil at MK made it fit some how. And as you can see in the picture, looks fine now
Leigh
| posted on 29/1/06 at 07:51 PM |
Can you turn the link pipe around Kev? Also, the 4:2:1 piece looks slightly twisted. It might be worth slackening the headers off and see if you can
twist the 4:2:1 to square it up. Then mess about with the link pipe and silencer.
Phil
Lurch88
| posted on 29/1/06 at 07:52 PM |
I had exactly the same problem. I saw Phil (From MK) at the Exeter kit car show and he said loosen off all the primary pipes and rotate them (primary
pipes) .I tried this when I got home and it did improve the alignment a bit.
Then I took the link pipe to work and cut and shut it.
Although your link pipe does look different to mine.
Here’s a picture
Lurch88
| posted on 29/1/06 at 07:53 PM |
Try the picture again
kev R1
| posted on 29/1/06 at 07:56 PM |
think my 4-2-1 connector may actually be on wrong i'll have another bash tomorrow.
e-mail me some pics leigh and also where you got the carbon for the rear cover from cheers
mandbsheldon
| posted on 29/1/06 at 08:13 PM |
Kev, pics sent, carbon sheet from MK.
Leigh
OX
| posted on 29/1/06 at 09:37 PM |
my brother and me are trying to fit his exhaust as well,,the 4-2-1 collector seems wrong
mangogrooveworkshop
| posted on 29/1/06 at 10:35 PM |
Its the link pipe thats to short and hasnt got the bend quite tight enough. On Macspeedys car this was the same problem solved by sticking two bits
scaffolding up each end and getting round when heated. Easy does it or you will flatten it. Ive got exactly the same prob to fix shortly.
zxrlocost
| posted on 30/1/06 at 05:32 PM |
I bought mine from martin at MK Engineering
good old fashioned Business minded
tell him what you want he tells you when it will be ready for I went and fetched it and it was ready on the side in his workshop! cant say that about
all the others
hand over the cash no pissing around fitted first time!
Winston Todge
| posted on 30/1/06 at 06:09 PM |
Just wondering if you tried turning the link pipe around the other way, so that from manifold to can you have the longer link pipe section followed by
the shorter?
Yours seems to be fitted shorter then longer?
Just a thought...
