Paul G
| posted on 30/1/06 at 11:14 AM |
MK R1 cat rental
Hi all
Just trying to fit my cat which I rented off MK for £50. I was told it was a straight swop for the end can of my standard MK supplied R1 exhaust
system.
Turns out they are completley different sizes - the mounting points are 4 inches out!, I rang MK and they said no one else has had this problem. have
a look at the attached picture - what has everyone else done? only thing I can think of is cutting up my middle link section but I'd rather not
have to do this!
The one on the right is the rented item
[Edited on 30/1/06 by Paul G]
andyharding
| posted on 30/1/06 at 12:46 PM |
Does the tail pipe on the cat touch your tyre? If not couldn't you just make up a bracket to ectend the mounting?
Paul G
| posted on 30/1/06 at 01:08 PM |
Ay up Andy - yeah it was way past the tyre I've gone and chopped my link section now so at least the cat fits. Have to get a new link section
now though when I pass the SVA..... Nowts ever simple!
DarrenW
| posted on 30/1/06 at 01:17 PM |
Cat rental £50   . Was that just a deposit or the cost? Most other manufacturers loan them to builders for a lot less than that.
andyharding
| posted on 30/1/06 at 01:27 PM |
Have you booked the SVA yet?
And did you get to the bottom of the misfire?
Paul G
| posted on 30/1/06 at 02:40 PM |
I know £50 is a bit excessive (plus a £200 deposit!) but I thought it would be worth it as it would be a guaranteed straight fit, well thats what I
was told at least!
Andy, not booked SVA yet - got my car in for an emissions test tomorrow so if thats ok I'll go ahead and book it.....
Put some new sparks in but I've not been for a test drive yet (you know the faff I'll have getting my car back in my drive pointing the
right way!) - but it does sound better so guess I can put it to the test tomorrow on the way to the garage!
kev R1
| posted on 30/1/06 at 09:19 PM |
yout standard can looks a little bit short and small to me what is the length of your standard can and the mk one, cheers kev
Paul G
| posted on 31/1/06 at 09:05 AM |
Hi kev - heres the picture I should have uploaded in the first place with dimensions on it. You can also see that the rented one is a lot thicker
which caused it to touch the bodywork.
The standard one I have must be the correct size as when fitted the tip of the exhaust sat in exactly the right place just before the rear arch.
Paul G
| posted on 31/1/06 at 09:07 AM |
Doh!
Paul G
| posted on 31/1/06 at 12:03 PM |
well just had a pre SVA emissions test done:
CO - 1.3 (max limit is 0.3)
CO2 - 12.06
COc - 1.46
HC - 904
O2 - 3.35
LAMBDA - 1.075
needless to say it would fail at SVA, and I guess this might account for my rough running and misfiring. Any ideas where to go from here?
Paul
andyharding
| posted on 31/1/06 at 12:10 PM |
Is there a mixture screw you can turn down?
Paul G
| posted on 31/1/06 at 12:22 PM |
I've twiddled with the mixture but it didnt seem to help much and the cat was nice and hot. I've got it booked in now at a place in
Normacot that know a lot about R1's so hpefully they can help.
Is there any info I need to tell them to help set it up? I've heard about these air bleed systems but not sure if its needed.
Paul
kurt
| posted on 1/2/06 at 06:41 PM |
I am also approaching the completion of an MK with an R1 engine and I am getting concerned about the emmisions part of the SVA. I would be interested
to know how you get on so please keep updating this thread.
I have to say that your silencer does look small compared to mine from MK which is more like the size of the Cat silencer you have rented from the. I
phoned them today and they said it is the same size and should be a direct replacement, so I don't know what has happened with yours.
Keep us posted how you get on.
Cheers, Kurt
kev R1
| posted on 1/2/06 at 08:29 PM |
just measured my can and it's almost identical to the mk cat one think you've got a stray one there mate(that's can not cat!!! )
Paul G
| posted on 1/2/06 at 08:32 PM |
Its wierd how the original smaller system all fits perfectly - Ah well it probably saves a few kg over the usual sized one then!
I've got my car booked in on friday to balance the carbs and hopefully sort the emissions so I'll let you know what they do
Paul G
| posted on 2/2/06 at 10:29 AM |
Cheers for the info Snoopy!
Paul G
| posted on 3/2/06 at 12:59 PM |
Well it flew through the emissions co was 0.04% and HC was 127ppm! I looked in my local B&Q for something to make an air bleed system with -
ended up using 'B&Q quarter circle sprayer with valve, 40cm pipe and joiner (for use with B&Q easy watering system)' Everything I
needed was in the kit just needed to put a thread on the end of the joiners. Was in the sale too for £3.98 (the kit contains 3 but there was 1 loose
on the shelf and they let me have that for nowt).
taking the air filter off made a major difference, HC was about 300ppm with it on!
Thanks for all the advice, now time to book the SVA!
andyharding
| posted on 3/2/06 at 01:21 PM |
Well done that man!
