New Topic New Reply
Author: Subject: MK Front Lower Wish Bone Ball joint
mad4x4
posted on 3/3/03 at 02:17 PM Reply With Quote
My mate has an old MK "Locost" with a de-dion axle. He has been told it is was "Wide Track.
The front lower wish bones are slightly short (2") than the current Indy. and have a flat plate at the end with 3 M12 (ish) holes drilled in a triangle ( One near the car and two outer most).
From this description does any one have an Idea what ball joint this would be.
I'll try and post a photo if no one answers.
MK9R
posted on 3/3/03 at 02:20 PM Reply With Quote
Cortina?
Jon Ison
posted on 3/3/03 at 03:06 PM Reply With Quote
think you can remove the "?" Mike, i would say your spot on..............
auzziejim
posted on 3/3/03 at 04:11 PM Reply With Quote
Do you mean these?
[img]http://image1ex.villagephotos.com/pubimage.asp?id_=1731687[/img]
bugger it aint workin so copy and paste the link!
James
[Edited on 3/3/03 by auzziejim]
flange nut
posted on 3/3/03 at 06:11 PM Reply With Quote
The Cortina bottom joint has four fixing holes and the rear of the fixing plate is bent upwards. The Tiger Avon uses a joint with a triangular fixing plate and the book says that comes from a Fiat 124.
New Topic New Reply
