New Topic New Reply
Author: Subject: Pinto into Indy: how??
ed_crouch
posted on 5/2/06 at 03:07 PM Reply With Quote
Hello everybody.
Are the engine mounting holes pre-drilled in the indy chassis, or is it a case of craning one's Pinto into the bay and measuring between the gearbox output flange and diff flange and drilling holes in the right place etc..???
Ta.
Ed.
P.S. If i have to drill the holes myself, presumably I want the engine as far back as it will go??
I-iii-iii-iii-ts ME!
Hurrah.
www.wings-and-wheels.net
tom windmill
posted on 5/2/06 at 03:15 PM Reply With Quote
hi,
i have a pinto in my indy and you have to drill the foles your self although there is only realy 1 place it can go you cant move it that much but i have just got mine as far back as it will go
HTH Tom
ed_crouch
posted on 5/2/06 at 03:17 PM Reply With Quote
Tom,
OK. Thanks.
Ed.
Hurrah.
MkIndy7
posted on 5/2/06 at 05:20 PM Reply With Quote
Sounds like it depends on when you bought your kit, ours is about 2 years old and I'm sure it had the holes pre- drilled
jacko
posted on 5/2/06 at 06:54 PM Reply With Quote
Hi my chassis was pre drilled
Jacko
indykid
posted on 5/2/06 at 07:04 PM Reply With Quote
as was mine.
i picked my chassis up on 31st jan 2004 fwiw. the holes are just in the middle of the plates.
you have to drill your own gearbox mount holes though.
hth
tom
[Edited on 5/2/06 by indykid]
jacko
posted on 5/2/06 at 07:20 PM Reply With Quote
Hi was your chassis for a bike engine ?i dont think thay are drilled when you get them new from mk
Jacko
whitestu
posted on 5/2/06 at 08:32 PM Reply With Quote
Bought mine in Nov 05 - engine mounting holes were drilled [noth that thay fit my engine]. Gearbox ones were not.
stu
donut
posted on 5/2/06 at 09:05 PM Reply With Quote
Mine were not drilled so go with 1st suggestion
ditchlewis
posted on 6/2/06 at 08:50 AM Reply With Quote
the holes in my chassis were pre drilled for the engine, but the gear box were not.
ditch
Jonte
posted on 6/2/06 at 09:31 PM Reply With Quote
Mine was delivered february 2004 and had the engine mounts hole drilled, but not for the gearbox
Click it
New Topic New Reply
