bigbern
posted on 23/2/06 at 10:52 PM |
fuel guage sender unit
ive just purchased a mk indy blade,
and its got no fuel guage!!
what sender units do you guys use??
lovein the site
Thanks Rich
bimbleuk
posted on 24/2/06 at 08:41 AM |
I use a VDO gauge and dip tube sender. Not the cheapest and you need the sender matched to your tank depth. Plus points are the gauge is very well
damped and more linear than a swing arm sender. Also you can pack your tank with foam more easily if required.
I got mine from Merlin Motorsport.
[img][/img]
rusty
posted on 24/2/06 at 10:51 AM |
Sorry to hi jake bet where can you get these and also where can you get tank foam
posted on 24/2/06 at 11:31 AM |
lovein the site
Thanks Rich
Rich, on our Blade engined Indy we had no gauge. Just simply worked out how many miles it would do on a full tank and reset trip every time we filled
up. If you want something more sophisticated..... use a stick
cryoman1965
posted on 24/2/06 at 11:48 AM |
Hellfire does this not cause a problem with the sva man. I was lead to believe that you should be able to see the contents of the tank. ( The gauge
must read full and the tank must be full.) Is what i was actually told.
Have i actually mis-interpreted the information?
DarrenW
posted on 24/2/06 at 11:54 AM |
SVA man didnt check my fuel level. He just asked me how much was in. I said it was full when i set off and ive driven 45 miles - he was happy with
that.
2 things they check for - no leaks and sufficient fuel to complete test. I could have fell foul on the leaks bit but he was Ok with me.
I have been told that if you have guage fitted then you can earth it out to read full. Otherwise if no gauge take a suitable dip stick so you can
prove full. As awlays if in doubt call them so they can confirm what they prefer.
On the sender front - i fitted the ETB sender that came with DD2. Its a bit fiddly to set up but works OK.
