kev R1
posted on 27/2/06 at 07:24 PM |
indy cycle wings
anyone got any pics of how they have mounted there cycle wing brackets to the fibre glass arches? ie through the side or bent around the contour they
are the round arches as opposed to ones where tjey've got a flat to mount the brackets,kev
mandbsheldon
posted on 27/2/06 at 07:33 PM |
Or you could do them like mine. See picture below
Leigh.
posted on 27/2/06 at 07:38 PM |
how far below?!
mine were niitially fitted by cutting the arch round the bar, its looks a bit bleak IMHO. Much better bent as required, but not easy with 6mm bars.
kev R1
posted on 27/2/06 at 07:49 PM |
thanks for the help guys and cracking pic leigh! just checked the arches and they're not looking wide enough i've got 205 R888'S
on and there's literally about 4mm either side of the tyre to the arch so i'll never manage to get the u-trim on for sva, looks like new
ones on the cards.
mandbsheldon
posted on 27/2/06 at 07:50 PM |
Still can't attach pictures, just not cut out for this
mandbsheldon
posted on 27/2/06 at 07:53 PM |
What you got left Kev? How far off are you?
indykid
posted on 27/2/06 at 08:07 PM |
quote: Originally posted by kev R1
thanks for the help guys and cracking pic leigh! just checked the arches and they're not looking wide enough i've got 205 R888'S on
and there's literally about 4mm either side of the tyre to the arch so i'll never manage to get the u-trim on for sva, looks like new ones
on the cards.
get dax ones!
mmmmmmmmmmmmmmmm
the standard mk ones fit much better if you take about 2/3 of the side flanges off. it makes them a lot more pleasing on the eye, and makes the u trim
less vertical, so gives less bulk across the width of the tyre.
tom
PAUL FISHER
posted on 27/2/06 at 08:31 PM |
quote: Originally posted by JoelP
how far below?!
I didn't think you bothered with such things as cycle wings Joel
kev R1
posted on 27/2/06 at 09:27 PM |
i rally wanted some wider ones instead of messing filing them down
not too much to do leigh got the cycle wings to do couple of connections for the plumbing lots of wire tidying! nose cone on couple of other bits and
pieces and that should be about it!
