whitestu
| posted on 28/2/06 at 01:39 PM |
Bending aliminium trim
Might be a daft question, but how have people bent the aliminium trim that goes over the curved bit of the Indy side panels.
As it is L shaped presumably notches need to be cut out of the vertical bit to allow it to bend.
Stu
PAUL FISHER
| posted on 28/2/06 at 01:49 PM |
You don't need to cut notches out of it to get it to bend,it bends ok without,I bent mine round a 17" tyre,this just shaped it to just about
the correct radius.
just to add,you will need to cut a small notch out at the base of the bend,were it bends back on its self,if you no what I mean,you can see this in
the picture.
whitestu
| posted on 28/2/06 at 01:52 PM |
Thanks Paul
indykid
| posted on 28/2/06 at 07:58 PM |
don't bend the internal corner, mitre it.
no offence meant paul, just offering a different way. just cleans the lines up a bit.
it's a bit of a see you next tuesday to get right, but well worth it in the end.
i used a small oil barrel we use as a bin, to form the curve, but any large radius round former will do. just make sure it's smaller than the
arch curve, as it's a bugger for springback.
tom
jos
| posted on 1/3/06 at 10:27 AM |
I was worried bending mine when it came to it but in the end you just have to trust that wacking it with a big hammer or mallet will do the job &
didnt harm mine when I did it.
