skydivepaul
posted on 13/3/06 at 11:19 PM |
clutch cable?
you may have seen a previous thread in which last Thursday I took the MK to holeshot racing for a dyno tune. After a morning of loading / unloading
the car strapping the car down on the rollers and warming the engine up ready for the first run the bloody clutch cable snapped
Still could have been worse i could have been out driving on the road.
Anyway I went out and bought a brand new R1 clutch cable>had a quick look at the original cable and it looks like a ford item.
Seeing as i cheated and didnt build the car what do you normally use for the clutch cable - -Sierra or bike engine??
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
Dillinger1977
posted on 14/3/06 at 08:58 AM |
MNR do a real heavy duty clutch cable, very nice (and reflected in the cost! )
skydivepaul
posted on 14/3/06 at 12:01 PM |
quote: Originally posted by chris mason
paul you can just use the r1 one if you like or a bicycle brake cable or something more substantial.
the choice is yours, did your cable snap or did it just pull out of the end?
cable had snapped / frayed at the point where it goes through the bulkhead to the clutch pedal. I need to look to see if it is rubbing on the hole
Chris
HD CCTV
IP security systems
posted on 14/3/06 at 12:29 PM |
Paul,
you can buy all the necessary components (inner cable, outer sheath, nipples etc) you need to make a clutch cable, from Vehicle Wiring Products by
mail order. You can then make it as strong as you wish
Phil
VWP Link
[Edited on 14-3-06 by Hellfire]
skydivepaul
posted on 15/3/06 at 10:19 PM |
Thanks for the link hellfire.
I am fitting the R1 clutch cable that i bought as the outer cable fits good. I need to extend the wire innner to fit the clutch pedal properly.
Thanks again
Paul
HD CCTV
IP security systems
Taz Surfleet
posted on 16/3/06 at 02:07 PM |
" I need to look to see if it is rubbing on the hole"
putting a rubber (grommet) will help there
