Jubal
posted on 17/4/06 at 06:26 PM |
Suspension setup?
Did my second trackday in the Indyblade this past weekend. It was extremely good, in fact I was astounded at how quick the car was, keeping up with a
well prepped and well driven Caterham Superlight R (130hp)
However, I think it can go faster. I was getting some understeer. Given the light blade engine and my pie challenged weight at the back it's
understandable but I'd like to try and dial it out and generally have the car set up properly. I'm not sure I'd know where to start
so I'd prefer to hand it over to an expert. Does anyone have a recommendation, preferably in the NW? I tried plays kool a few weeks ago but they
have closed down.
ernie
posted on 17/4/06 at 06:57 PM |
I`m going to try Procomp, based in Birmingham for my race car they are said to be very good. I don`t know if they can do it at a race venue, they do
attend at some 750 club meetings and tere is one at Cadwell on April 30/ May 1st. phone number is 0121 350 3258. If you use them let us know how
you get on, cheers
posted on 17/4/06 at 06:59 PM |
i believe mark at mnr has corner weight stuff and wheel alignment stuff. Does that count as 'going to the enemy'?!
Jubal
posted on 17/4/06 at 07:20 PM |
Thanks for the details. I'll see what they say and let you know how I get on.
mad-butcher
posted on 17/4/06 at 07:41 PM |
there's an article on here by gregors can't remember the rest of his name sorry about bump steer I spent about 3 hrs setting it up had to
lift the rack by about 11mm I was amazed at how much toe in toe out you get when you lift or lower the car. what I mean is,, my blade is set for 1.5mm
toe in..disconnect the top mounts of the front suspension put a jack under the car and lift it up as it would be under acceleration now measure the
toe in, in my case it went to about 5mm toe out, now lower the jack to what it would be under braking/cornering and measure again mine was about 4mm
toe in. by lifting the rack a few mm at a time and checking you can get to the point were you only have about .5mm difference it's time
consuming and gets a bit boring but I found it worth while the next time we had the car at a trackday
Tony
