mad-butcher
| posted on 12/4/03 at 05:13 PM |
brake lines again
first tnx to viper found the relevant section in the book of words. so they can go on at a latter date or go on the lads custom corsa. so does anyone
have a closeup pic or two of the little bit of rigid pipe so I can see what fittings I need to scrounge
regards
Tony
Viper
| posted on 12/4/03 at 05:59 PM |
Just posted a pc of a sva friendly braided brake pipe. not the bit you were looking for but it will give you an idea what ou will need to do to the
goodridge hose you have..
wicket
| posted on 13/4/03 at 03:29 PM |
Viper
Who's the supplier of the SVA friendly brake hose in the picture ?
Viper
| posted on 13/4/03 at 03:37 PM |
That is actualy off of a TVR (just happened to be donated a set of four )
locodude
| posted on 13/4/03 at 03:45 PM |
Tony
MK can now supply these at £10 each I think. Just cover them in spiral wrap for the test.
wicket
| posted on 14/4/03 at 07:27 PM |
BSR-Aerotek have a range of 'SVA compliant' swaged hoses called Moto-flex which can be fitted with coloured sleeving to protect for the
abrasive braid. Talk to Terry, really helpful.
www.bsr-aerotek.com
Viper
| posted on 14/4/03 at 08:52 PM |
under the wrap there is a label says Goodridge..
