mad-butcher
| posted on 30/5/06 at 07:14 PM |
R1 Engine mounting Still puzzled
Hi guys
Still don't know which is the best method of mounting the R1 motor, am I better off having the cam cover running parallel to the top tube as
per the blade or having a small gap at the front and a larger gap to the rear
Tony
smart51
| posted on 30/5/06 at 07:57 PM |
it is better for the crank shaft to be as parallel to the centre line iof the car as possible. small gap at the front, bigger at the rear. You want
the smallest angle possible in the UL of the prop. Zero is ideal
speed8
| posted on 31/5/06 at 05:59 AM |
Just be careful if you have an injected R1.
Since I got my bodywork I've found out that my thermostat pipework doesn't fit under the bonnet and needs to be remounted elsewhere which
is quite frustrating.
locoboy
| posted on 31/5/06 at 06:20 AM |
quote: Originally posted by smart51
. Zero is ideal
there are many that say that running a prop with zero deflection will knacker it - dont shoot me just relaying what i have heard!
here is how i have done mine
  engine placed in prior to moun
[img][/img]
Locoboy
chockymonster
| posted on 31/5/06 at 07:54 PM |
Glad I'm not the only one puzzling over that. How have you gone about it?
richardR1
| posted on 31/5/06 at 08:21 PM |
Couple of pics of my 03 R1 Indy if it helps.
  11/10/05 9
  11/10/05 7
MK Owners Club Member 1015
| posted on 31/5/06 at 09:50 PM |
Rich, somebodys nicked your air filter.
DIY Si
| posted on 31/5/06 at 09:59 PM |
And the bonnet!
richardR1
| posted on 31/5/06 at 11:20 PM |
Didn't realise I had missed comedy hour on here  Pleased to report that this evening's little blast was completed with bonnet and
filter firmly in place.
gttman
| posted on 1/6/06 at 07:36 AM |
Rich
How does your R1 injection engine fit?
I found that the std engine mount possition left the sump a full 2.5inches below the chassis and thus very close to the ground...... I have had to cut
my engine mounts out and raise the engine 2inches (still clears the bonnet with the airbox on tho).
Apparently this is due to differnces between the Injected and non injected R1 engines!
Andygtt
Please redefine your limits
tks
| posted on 1/6/06 at 08:04 AM |
nice horn!
