mad4x4
posted on 2/7/06 at 09:42 PM |
Indy Seatbelt Mounts :(
Mr sva say's there too low
I have taken 2" out of the seat but still they are too low.
Asked Mr SVA (in aberdeen)about spacers and he said no I'd need to raise the anchor point
Seats are clicky
Due to having chrome cobra style rollbars I cannot easily weld in a horizontal bar like so many.
WHAT DO I DO
2" out of seatbase
Prior to Seat mod
Rollbars
[Edited on 2/707/06 by mad4x4]
Scot's do it better in Kilts.
Howlor
posted on 2/7/06 at 09:49 PM |
Can you put some spacers to mount your harnesses higher. Mine are on bush crush tubes with M12 bolts through. Gives you about 40mm.
mookaloid
posted on 2/7/06 at 10:01 PM |
Are your seats on runners? could you take the runners out and bolt straight to the floor temporarily?
MkIndy7
posted on 2/7/06 at 10:03 PM |
They look the same as the rest on the MK mounts.
Think its just the height of the seat base thats the problem, same as with the Cobra 7's they just scrape under with no runners attatched and
bolted straight to the floor.
stevebubs
posted on 2/7/06 at 11:31 PM |
Make a plywood and foam seat and put it through SVA with that.
Post SVA put your nice seats back in
scottc
posted on 3/7/06 at 09:47 AM |
or some fibreglass seats
http://www.locostbuilders.co.uk/viewthread.php?tid=47934
TimC
posted on 3/7/06 at 10:20 AM |
Get him to push 'Nigel' down into the seat to simulate a person sinking into the seat. My MK passed with Cobra 7s WITH runners by talking
the inspector into doing this.
TC
JAG
posted on 3/7/06 at 10:22 AM |
Hi Mate, I had the same problem and so I made this;
seat belt mod' finished/fitted
Passed SVA at Nottingham no problems.
Justin
mad4x4
posted on 3/7/06 at 01:15 PM |
Now that is one Idea I like, needs to be worked through a little for my application
could it be made out of round bar?
JAG
posted on 3/7/06 at 01:35 PM |
It could be made from almost anything so long as it's strong enough. I used 2mm mild steel plate with a centre web to strengthen the folded
joint.
More pictures in my photo archive under '2005'.
Best of luck.
Justin
