Author: Subject: R1 fuel sender wiring?
kurt
posted on 8/7/06 at 03:25 PM Reply With Quote
When I switch my ignition on I'm getting an error reading on my tacho (8000rpm) which means the fuel sender is incorrectly connected. I'm not using a standard R1 sender, but a Durite sender supplied by MK. I've connected it according to the instructions with the connection from the sender to the green and white on the R1 loom, but the diagnostics don't like it. What do I do?
MkIndy7
posted on 8/7/06 at 03:53 PM Reply With Quote
Does it display an error with no sender attatched?
If so does it display the same fault?
I'd guess that its a 2 wire sender, 1 would go from Earth, through the sender and then to the dial through the green and white wire.
So either its not connected up right or the sender is the wrong resistance range.
[Edited on 8/7/06 by MkIndy7]
kurt
posted on 8/7/06 at 05:14 PM Reply With Quote
Yes, with the sender disconnected the error still shows. I have looked on another thread and somebody else has conned the diagnostics by fitting a 1K resistor between the green and white wire and earth. I think this makes the diagnostics think there is fuel or something. The sender appears to be one wire and I have a fuel gauge that I could fit that goes with the sender. If I can con the diagnostics this may be the way to go.
MkIndy7
posted on 8/7/06 at 05:32 PM Reply With Quote
The sender will need 2 wires surely, unless normally it earths through the tank in which case you'd have to replicate that.
