david
| posted on 5/5/03 at 11:20 PM |
Brake P clips with rubber inserts
Can the above clips be purchased and if so where
highspeeddirt
| posted on 6/5/03 at 12:30 AM |
www.vehicle-wiring-products.co.uk
They do rubber lined P clips in both steel or aluminium in various sizes.
| posted on 6/5/03 at 07:42 AM |
I got mine in a local motor factors - they're common items.
GO
| posted on 6/5/03 at 08:30 AM |
What do people feel about the plastic p-clips? Not up to the job?
carnut
| posted on 6/5/03 at 08:48 AM |
i personally think they are better as they save weight and look smaller and neat. This is what the likes of Caterham use.
GO
| posted on 6/5/03 at 09:01 AM |
Cool, thats what I wanted to hear! Same thoughts as you, lighter, smaller, neater and a lot cheaper!! Main concern was the strength of them, i.e. will
they crack after a while, and would they be an sva fail with that in mind. However, if caterham etc use them then I guess they must be ok.
Cheers. Graham
scutter
| posted on 6/5/03 at 07:53 PM |
I wouldn't worry about the strength of plastic P clips, just spend the day taking a Dutton apart(V enjoyable) even after 15+years the clips had
to be drilled out.
Dan.
Viper
| posted on 6/5/03 at 08:14 PM |
Try www.tifosi-devon.co.uk thats where i got mine, 9mm ones £3 something for 100...(plastic)
