kev R1
posted on 15/8/06 at 07:44 PM |
R1 indy passed today notts!!!! yyyyyyyaayyy
well second time lucky!!!
sailed through no probs!!
was a bit miffed when turned up at dvla with all docs and everything only to be told i had to wait till fri to get my reg no and tax disc!!!
gggggggggrrrrrrrr!!!!
thanks again for all the help i've recieved you know who you are!! thankyou!!!!!!
woooooooooooohoooooooooooooo!!!!!!
bob
| posted on 15/8/06 at 08:51 PM |
Well done kev
Hammerhead
| posted on 15/8/06 at 08:59 PM |
Nice one!!
cryoman1965
| posted on 15/8/06 at 09:07 PM |
Congrats. Great feeling.
Winston Todge
| posted on 15/8/06 at 09:14 PM |
Looks great bud!
Got me some of those side repeaters too. All SVA okay?
Ta,
Chris.
welderman
| posted on 15/8/06 at 10:50 PM |
Well deserved thumbs up Kev.
NOW MAKE THAT PICTURE SMALLER.
Thank's, Joe
I don't stalk people
mandbsheldon
| posted on 16/8/06 at 05:44 AM |
nice one kev!!!!!!
leigh
kev R1
| posted on 16/8/06 at 04:56 PM |
sorry guys! it is a bit large innit"! lol
side repeats are fine but had quite large indicators on front that could be seen from side on!
kev R1
kurt
| posted on 18/8/06 at 06:21 PM |
Well done, it must be a great feeling.
A quick question though. I've got my retest in two weeks with a carbed R1. It failed on emissions last time and I need to know where you set
your idle mixture screws to get it through (assuming yours is carbed also), mine are currently two and half turns out. Also did you disconnect your
Air Induction System (if it had one) to richen it for the lambda test.
Well done again, and I'd much appreciate any info on the above.
Cheers, Kurt
kev R1
| posted on 18/8/06 at 07:17 PM |
first of all yoou'll need a cat,
take the air filter off,
start at two turns out on all four carbs,then turn each screw 3/4 turn in,
then adjust it to get the C0 down to zero! and the rest should match!
i've got a C0 meter if you want it for £20 if you can't get to a patient mot place!,kev
kurt
| posted on 20/8/06 at 04:40 PM |
Thanks Kev, but I still have more questions.
Why take the airbox off? I've turned mine round so it fits under the bonnet, and from what I can tell most say the engine runs better with
rather than without it.
Also, does screwing the mixture screws in richen or weaken the emissions in terms of the lambda reading, because mine was too lean and I'm
hoping to fiddle it at the test by adjusting the screws if it fails again, so knowing which way does what would be useful.
Cheers, Kurt.
kev R1
| posted on 20/8/06 at 08:49 PM |
i took the airbox/filter off to get more air into the carbs( made about 0.5 difference to the CO reading).
screwing the jets in makes it leaner so in your case obviously you'll need to screw them out a touch,do each one the same amount! factory
setting for an r1 should be 2 and 1/2 turns out.don't screw them in too tight as you'll damage the jet-seat. hope this helps,kev
kurt
| posted on 21/8/06 at 04:27 PM |
Cheers Kev, hopefully I'll posting a pass on here next Friday 1st Sept.
Kurt.
