georgeg
| posted on 12/5/03 at 10:08 PM |
fuel overflow
I'm just about to fit mk's plastic tank.Where does the overflow go? Mine has a small vertical pipe at the opposite end to the filler neck.
Viper
| posted on 12/5/03 at 10:11 PM |
overflow?
are you sure its not a breather? a breather should vent to the atmos preferably hrough a one way valve.(failing that looping the pipe a couple of
times..)
locodude
| posted on 13/5/03 at 05:09 PM |
It's a breather not an overflow and Mr Viper is correct.
CairB
| posted on 13/5/03 at 05:43 PM |
georgeg,
Do a forum search on vent - it's been discussed earlier.
The breather becomes an overflow when the cars inverted and the valve doesn't do it's job - neither failure modes desirable .
Colin
