dan220
posted on 7/9/06 at 08:19 PM |
Hey guys, i'm new and i need some help!!!
hi everyone, this is my first post and i'm looking for a bit of help. I'm building a Indy with a 2.0l pinto and i reckon i'm about
30% of the way through the build.
i'm just about to start installing the cooling system but i'm not sure the best way to go about it, what componants to use etc.
Does anybody have and pictures or diagrams that would help me? From what i've read so far, an old polo rad would be best?? What about the
expansion tank?
Any help would be greatly appreciated
Cheers, Dan
graememk
posted on 7/9/06 at 08:22 PM |
hi, when i got to this stage i used the search button and read untill my eyes started to bleed
i have a micra rad and a rover 214 tank working on a 1.8 turbo nissan engine
others use polo but its a tight fit, have a look in dounuts pics from memory he has some cooling and rad pics
oh and hello and welcome
[Edited on 7/9/06 by graememk]
jos
posted on 7/9/06 at 09:12 PM |
I used a micra rad WITHOUT an expansion tank.
the top of the rad connects to the top of the engine. the bottom of the rad connects to the bottom of the engine. and the little hose connector above
the big bottom one connects to the carb having been routed under the exhaust headers and over the bell housing. its all connected together using
numerous different sizes of samco hoses
ayoungman
posted on 8/9/06 at 08:00 AM |
Pinto+ polo+ renault clio expansion tank
"just like that !"
iank
posted on 8/9/06 at 08:50 AM |
See this thread for a source of cheap new polo rads. They also do micra
rads but they are much more expensive!
I'd be wary of using a second hand rad personally, but many have got away with it.
DarrenW
posted on 8/9/06 at 02:09 PM |
Pinto, micra rad and no expansion tank for me too.
The only mod since is piping the rad cap overflow to a pop bottle as it had a tendancy to blow water out. Been fine since.
Get a decent fan and maybe fit bypass switch in case you need it on in traffic for a bit more cooling.
I got all of my fittings and Samco hoses from mac#1 - look great.
dan220
posted on 8/9/06 at 03:09 PM |
cheers guys, many more questions to come i think!!!
dan
donut
posted on 8/9/06 at 05:54 PM |
I have some pics in my archive. It's donut not dounuts!!
I used a micra rad, westfield top rad mounts (bottoms i made myself) Cooling tubes were flexy type from Halfrauds, Bottom hose i think was Cortina but
can't be certain. Header tank was Astra. Hope this helps.
