New Topic New Reply
Author: Subject: pinto engine mounts
jabbahutt
posted on 14/9/06 at 05:12 PM Reply With Quote
pinto engine mounts
Hi again
What length bolts are needed for the MK engine mounts to pinto as the metal is thinner than the original mounts and i obviously want as much thread as possible in the block. I take it 8.8 HT bolts are needed.
thanks for any help
posted on 14/9/06 at 05:15 PM Reply With Quote
from memory I think I used M8x25mm 12.9 socket caps with plain washers as I had some lying around, but 8.8 should be fine. If you want to check the length, just slide a smaller bolt into the hole until it bottoms out to measure how deep the holes are.
New Topic New Reply
