Metalhead
posted on 4/10/06 at 03:20 PM |
Rear wishbone lock nut.
Hi all,
My first time posting here so bear with me
Does anyone know the size of the thread on the rod that passes through the top rear wishbone tube? It's the bit that allows the camber to be
adjusted if that makes sense?
Mine had lock nuts tightened up against each other holding this together which undid themselves causing a "moment" . Is there a
more secure method for doing this? Nylocs?
Cheers people!
StevieB
posted on 4/10/06 at 03:28 PM |
Welcome!
I've had the same worries (but no 'moment of unique occurance' as yet!).
Maybe I'll look at getting a large diameter nylock now as well!
[Edited on 4/10/06 by StevieB]
cryoman1965
posted on 4/10/06 at 03:46 PM |
The nut size is a M20. They are not readily available. Phone MK and explain.
I had the same prob 2 weeks ago. Noticed just in time. Just about to leave the pub when i knocked the wheel, and it moved side ways 5mm.
Now secure with Loads of Locktite and had a Friend fit a grub screw to each of the outer Nuts.
Cheers Nige
Metalhead
posted on 5/10/06 at 12:58 PM |
Thanks for the help and the welcome guys. Seems like a nice friendly forum this
I'll give MK a bell then. Shouldn't be too hard to get hold of M20 ones though. Then again it looks like a very course thread to me so
maybe thats the problem with availability?
cryoman1965
posted on 5/10/06 at 09:16 PM |
Standard M20 nuts are no problem to find but they are M20 Half Nuts. (On mine they are anyway). The 2 main suppliers i use dont stock them but will
order if i want 1000.
mad-butcher
posted on 7/10/06 at 12:35 PM |
I drilled a hole through it and fitted a split pin (didn't have any R clips that size)
tony
