ned
| posted on 29/5/03 at 04:24 PM |
Rolling Chassis stage..
I'm trying to budget for buying a chassis and getting it to the rolling chassis stage. I have problems with building and storage
facilities/space, so I figure the sooner I can build one to rolling chassis stage the easier it will be if necessary to move it!
This also gives me a good target/timescale to aim for.
So far I have thought up the following (though I'm sure I'm missing some bits)
From MK:
MK indy basic kit
MK ball joint set
From Donor:
wheels
uprights
brakes
axle
diff
Other:
dampers/springs (still undecided on which ones)
paint for chassis
Are there any other parts I need to get it to rolling chassis only stage (I know I haven't included steering rack/column which will
obviuosly come from donor)
Thanks,
Andrew
ps I may be being OTT, but I like to be well organised and plan ahead!
I'm sure someone who's built one will have more insight than me! (hindsight etc)
beware, I've got yellow skin
carnut
| posted on 29/5/03 at 06:01 PM |
You could delay buying the spring dampers for a bit by getting a bit of inch square tubing (or wood or anything) and having dummy dampers to take the
weight of the car.
MK9R
| posted on 29/5/03 at 07:55 PM |
Get the floor on first job (it comes with MK kit), but its a lot easier to turn upside down when there is nothing attached. Plus you can sit in it and
make reving noises
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
