rear track
got my razors from motorworld (did you know a 10% discount is normal only if you have the cheek to ask.) mine only just fit in the arches so I'm
a bit uncertain.
what I need to know is my dif, drive shafts and brakes are off a 1.8 therefore 8" drums this got me to thinking if there was a difference in
rear track without wheels between 7 and 8" drums so I did a bit of checking up 7" drums the drum is 66mm deep, 8" drums the drum is
82mm deep this gives a difference about half an inch either side
my track is about 60.25" wheel mounting face of the drum to wheel mounting face on the other side measured from the rear of the drum cos I
haven't set the camber yet and it seemed the most neutral point
does any-one have the corresponding measurements for 7" drums or is there a web-site that contains all the ford specs
Tony
