StevenB
| posted on 12/12/06 at 12:03 AM |
MK Suspension Question
Can anyone take a look at these sketches and confirm if they are correct
Looking down on the upper WB on the drivers side with the upright fixture pointing up..is this OK?
StevenB
| posted on 12/12/06 at 12:05 AM |
And the rear passenger side hub carrier.
I have a funny feeling this isnt OK as the caliper carrier is not playing ball.
Steven
James
| posted on 12/12/06 at 12:11 AM |
Top picture is definately correct.
Make sure you have the w/bones the correct way round too... the BJ should 'point' upwards when the w/bone is level.
As for the rear... wait for someone with a 'proper' MK!
HTH,
James
- Muhammad Ali
StevenB
| posted on 12/12/06 at 12:19 AM |
James,
Yep, BJ is pointing up.
Thought i was gonna have to take them off when the centrelines didint match with the
bottom W/bones.
Steven
Marcus
| posted on 12/12/06 at 09:12 AM |
The centre lines are not supposed to line up! That's where the caster angle comes from.
Marcus
Because kits are for girls!!
mackei23b
| posted on 12/12/06 at 09:25 AM |
Hi there
Yes the drawings look correct, thought the rear MK carriers are handed. The inset should point to the rear to clear the calipers if using a disk set
up.
There is a pic in my archive of the front.
Ian
[Edited on 12/12/06 by mackei23b]
macnab
| posted on 12/12/06 at 11:14 AM |
fronts as is on my car, rear carriers are different cos my hubs not angled back like that causing me to have to weld brackets on to hold the calipers.
great.
