minordelay
| posted on 12/12/06 at 06:41 PM |
Clutch actuation
Has anyone built an indy with a hydraulic clutch, any info or picson this subject would be welcome. I discovered yesterday that ours is a late engine
non cable operated.
tks
| posted on 12/12/06 at 07:34 PM |
No problem
look at my pics!!
in facti have moven it another 40mm closer to the engine! Sow cant be a big problem really...
Tks
minordelay
| posted on 12/12/06 at 08:19 PM |
I was refering to the pedal linkage, I don't expect it will be that bad to do. It's just harder with 12 students breathing down your neck,
ultimately it's their project but I have to spoonfeed them a little.
DIY Si
| posted on 12/12/06 at 08:20 PM |
Pedal linkage is easy, you just need a clevis pin type attachment to allow for the swivel, then a bolt/ bit of threaded bar to the master cylinder.
Basically, just like the brake one.
[Edited on 12/12/06 by DIY Si]
Sun Tzu, The Art of War
minordelay
| posted on 12/12/06 at 08:29 PM |
Thanks, as I guessed. I haven't actually seen the master cylinder yet, MK have it, I am assumining that we will fit the bike m/cyl but seem to
recall them been a bit small!!!!
DIY Si
| posted on 12/12/06 at 08:40 PM |
Many people fit the bike brake cylinder in place of the bike clutch one. I think this is done to allow a wider range of bore options to change the
pedal feel. A smaller bore gives a longer softer pedal, and a larger one a shorter pedal.
mackei23b
| posted on 12/12/06 at 10:01 PM |
Some pics in my archive
In the end I ended up changing engines and didn't use this set up, though it bench tested OK and felt good. If you are interested you can have
the master cylinder, mount and pushrod for £35
If interested drop me a u2u
Ian
[Edited on 12/12/06 by mackei23b]
mackei23b
| posted on 12/12/06 at 10:02 PM |
and another
mackei23b
| posted on 12/12/06 at 10:03 PM |
and another!
mackei23b
| posted on 12/12/06 at 10:04 PM |
and finally.........
tks
| posted on 13/12/06 at 10:39 AM |
mhh
more elegant could be to use the rearbrake MC..
Also you see some people who just use the complete lever and attach a cable to that..
Tks
