New Topic New Reply
Author: Subject: Biggest Wheels on an indy
greggors84
posted on 12/6/03 at 11:02 AM Reply With Quote
Will 15" wheels with 205/50/R15 tyres fit on an indy without cutting the arches or anything.
I know the tiger cat couldnt really fit anything above 14s without the super cat kit.
What are the biggest wheels that would comfortably fit under the arches without cutting or using elastic bands as tyres.
Chris
ned
posted on 12/6/03 at 12:06 PM Reply With Quote
15" definately fits. the rim width/offset is more crucial.
205 should fit, though check the rim width with mk. 6" fits, don't know about 7" (wheel width before anyone comments)
I have heard that 195 is the widest warranted tyre, though have no first hand experience to comment either way.
Ned.
beware, I've got yellow skin
Viper
posted on 12/6/03 at 05:47 PM Reply With Quote
you shouldn't realy put a 205 on a 6" rim, better suited to a 7"
tony_cbr
posted on 12/6/03 at 08:21 PM Reply With Quote
I am running on 7.5x17's with
205/40R17 front, 215/40R17 rear
with no probs!
bikkel
posted on 13/6/03 at 06:37 PM Reply With Quote
hi tony cbr
do you know the offset you used ?( ET)
front /rear
bye koen
www.koendejong.com
zetec
posted on 14/6/03 at 08:51 AM Reply With Quote
MK recommend 195/50. Martin said that anything wider or lower profile can be cause problems with tracking or too coarse a ride as the car is light. I would go for sticky compound rather than large tyres. If you are going for looks then that is a different issue.
New Topic New Reply
