dilley
posted on 1/1/07 at 12:54 PM |
radiator position
are there any advantages in mounting a radiator at a different angle other than vertical?can you increase air flow?
Andrew.
Humbug
posted on 1/1/07 at 01:56 PM |
allegedly it can actually be better to have a slight angle because more of the airflow hits the fins directly rather than rishing straight through. I
don't think it would increase the actual flow, though. Something like this:
RazMan
posted on 1/1/07 at 02:34 PM |
Apparently 20 degrees is the optimum angle for max cooling efficiency
Raz
posted on 1/1/07 at 03:15 PM |
Yup. Slight angle works well... Presumably you'ld also want the fan at a slight angle to the radiator though for the same reasoning!!
I think if you're trying to wring the last drops of cooling out of a radiator setup ducting is more important.... and making sure there's
a way out for the air post radiator- this is often overlooked, resulting in a super hot engine bay and poor air flow through the radiator with the
open nose cone acting like a big air brake
dilley
posted on 1/1/07 at 04:38 PM |
good point chris
PAUL FISHER
posted on 1/1/07 at 05:00 PM |
I always tend to look at what companys like caterham do,they spend thousands of pounds in developement for me
Looks about 20 degree's to me
dilley
posted on 1/1/07 at 05:48 PM |
Thats a nice bit of work in that picture, you do get what you pay for.
any progress with the turbo paul?
Will you be ready for a blat at York in the summer?
Andrew
PAUL FISHER
posted on 1/1/07 at 06:39 PM |
Yes hopefully I will be at the MK York drag meet again this year,I sure Chris Mason is looking at getting another one sorted for this summer,last
years meet was such a great day,one of the highlights of the year for me
martyn_16v
posted on 1/1/07 at 10:39 PM |
quote: Originally posted by chris mason
but!! if thats right why don't the manufacturers just make them with the fins at a 20degree angle to start with, all the cars i've ever
owned have had the radiator vertical.
Packaging? A slightly oversized but vertically mounted rad will most likely take up less space than a 'correctly' sized rad mounted at an
angle, particularly in compact cars where the aim often seems to be keeping the bonnet as short as possible to allow the cabin to be bigger.
How about having a rad where the fins aren't perpendicular to the body of the rad itself, but at an angle (i.e. so when the rad is mounted
vertically the fins are 20deg off horizontal)? There's got to be a reason why these aren't manufactured, maybe adds too much cost, or you
wouldn't be able to have as many fins per inch of rad height?
