New Topic New Reply
Author: Subject: Radiator - Maximum width?
mackei23b
posted on 5/1/07 at 09:20 PM Reply With Quote
Hi there
What is the maximum width of radiator that fits under the MK nosecone.
What radiators have you used, I know POLO and MICRA are favourites, if you've used these ones what model / year did you use as I know they vary.
Many thanks in advance.
Best regards
Ian
Guinness
posted on 5/1/07 at 09:25 PM Reply With Quote
Some time back Chris_R wanted to know if a Rover rad would fit in an Indy nose cone. I cut a bit of card the same size and tried it for him.
http://www.locostbuilders.co.uk/viewthread.php?tid=22115
It measured 525mm L x 460mm H, but apparently the outlets would clash with LA/LB.
Rad in Indy Nose 1
Rad in Indy Nose 1
[img][/img]
Can't help with the spec from Polo / Micra though as I'm using an old Caterham one!
HTH
Mike
posted on 5/1/07 at 09:32 PM Reply With Quote
We've used Micra rads without any problems. Late 80's upto early 90's models. D to J prefixed registrations.
Phil
esn163
posted on 5/1/07 at 09:38 PM Reply With Quote
Hi
We used one of these - great quality and fits easy enough link
HTH
Ed
Indy Build Photos
** Build pages **
Photo Bucket Pics
dilley
posted on 5/1/07 at 10:02 PM Reply With Quote
Do you have a picture of it installed?
Andrew.
esn163
posted on 5/1/07 at 11:26 PM Reply With Quote
This any good?
you can kind of see the brackets that we used to fit it in this pic.
Just needed to bend some stainless (i think we used) - two identical top brackets and two U shaped ones for lower mounts - You can just about see the lower one half way down the LHS. Rad fixes to brackets using self tapping screws / bolts onto rad.
HTH
Ed
[Edited on 5/1/07 by esn163]
Indy Build Photos
** Build pages **
Photo Bucket Pics
worX
posted on 6/1/07 at 02:51 AM Reply With Quote
Micra Rads
I'm not 100% sure, but I think it's more important about the Micra Rads than just the year - Hellfire Phil is correct about the year, but I am pretty sure that it has to be the 1.0 litre Micra as the 1.2, 1.3, 1.5 etc all have the filler cap and entry/exit holes in the wrong place.
(you may need to check above!!!)
hth
Steve.
bodger
posted on 6/1/07 at 08:32 AM Reply With Quote
Hi ESN163, what fan are you using with the rad?
Jon
mackei23b
posted on 6/1/07 at 10:55 AM Reply With Quote
Many thanks
Ian
New Topic New Reply
