Catpuss
| posted on 24/2/07 at 04:20 PM |
Help (dropped my diff on the floor)
Arrg, fooking thing slid off the table and dropped about 2 feet. Looks OK (back plate was off) but the top hole on the back of the main body of the
diff broke off. Sort of like:
_____
/..........O <- Here
|...Back..|
O--------/
Its not part of the seal, but is that hole used on the indy assembly at all? If so I guess I'll have to have the loop welded on.
Also any tips on getting the drain bolt off cos I can't even move it using a MAPP gass blow lamp for heat.
[Edited on 24/2/07 by Catpuss]
Brddy proportional fonts
Hammerhead
| posted on 24/2/07 at 04:23 PM |
the four holes at the back of the diff are needed on the indy. The ones that you have to put the long diff bolts through. I had a crack in mine and
took it to MK, who welded it for me, not sure if they did it free or cost £10.
Catpuss
| posted on 24/2/07 at 04:27 PM |
Hi, not sure if its those as there looks like there is only two on the very back of the diff body (facing back to front, not left to right IYSWIM).
If you look at
Its the top left loop (but mine are push in rather than bolt on shafts)
Hammerhead
| posted on 24/2/07 at 04:34 PM |
heres mine fitted
Catpuss
| posted on 24/2/07 at 04:43 PM |
heres mine fitted
Cheers dude.
Looks like its just a loop hole for either feeding stuff through or help with the assembly line work
martyn_16v
| posted on 24/2/07 at 06:13 PM |
Prolly just a lifting eye. If you're sure that's the only damage then i'd use it...
Catpuss
| posted on 24/2/07 at 06:39 PM |
Thanks. Yep I've had a good look at it (the back was off at the time). It sort of slid off the bit of carpet so made an ungraceful sliding roll
rather than a bang. Turned the gears and given it a visual inspection. Nothing internal looks dented or feels any different. No bits of garage floor
debis entered the box.
Got the back plate off my other diff (its a 3.92) so I'm going to use that to get around the seized fill plug problem.
bodger
| posted on 24/2/07 at 08:16 PM |
Couldn't get my drain plug off, in fact round out the socket. Got MK to weld a bolt on since I was up there picking up my kit. The heat from the
welding seemed to do the trick & it then came off no probs with my impact wrench.
major
| posted on 25/2/07 at 08:50 AM |
The same thing hapened to me, only it was a G3 server. It slide of the table when I was working on the other end.
marc.
