mkblade
| posted on 19/3/07 at 11:09 PM |
steering column bush lower
hi guys i attaching a pic of the above i cant get the outer plastic part of the bush to fit in the rubber grommet correctly .should the outer plastic
part fit right inside the rubber grommet.
or has anyone got a pic of there steering i could have a look at thanks once again simon.jpg)
meany
| posted on 19/3/07 at 11:21 PM |
used washing up liquid to get mine in
meany
| posted on 19/3/07 at 11:23 PM |
plus...is it me, or have you got it the wrong way around.?
stevec
| posted on 19/3/07 at 11:25 PM |
In your picture would the steering wheel be to the left? If so the bush is fitted wrongly,
Steve.
[Edited on 19/3/07 by stevec]
indykid
| posted on 19/3/07 at 11:31 PM |
the bush is definitely fitted the wrong way round, and it shouldn't be too much trouble to get it in right.
just lube it up a bit if it is tight.
tom
mkblade
| posted on 19/3/07 at 11:52 PM |
so should it be fitted, so that the domed end is facing the engine bay (flat end inside car?)
also should the inner bush fit right inside the black rubber grommet like this ?.jpg)
indykid
| posted on 20/3/07 at 12:12 AM |
yep, so when you're sat in the car, that top face is nearest you.
tom
jollygreengiant
| posted on 20/3/07 at 04:04 AM |
I think we had this discussion a few weeks ago.
Yep. http://www.locostbuilders.co.uk/viewthread.php?tid=62365
& I beleive I u2u'd you as well with details as pictured & described above.
[Edited on 20/3/07 by jollygreengiant]
caber
| posted on 20/3/07 at 07:58 AM |
You might need to ease the hole the rubber bit sits in so the rubber can expand a bit with the bush pushed in
caber
James
| posted on 20/3/07 at 10:54 AM |
C-3PO to Chewie: "What? I'm backwards! You great, furry...."
- Muhammad Ali
zxrlocost
| posted on 20/3/07 at 03:03 PM |
is the wrong way and should fit in ok with some persisting
