stevec
posted on 7/4/07 at 03:03 PM |
Clutch stop for you BEC boys.
May have already been done, if so sorry. but here is my solution to BEC hydrolic clutch over travel,
I have used the threaded section of the willwood push rod to fit an adjustable sleeve with a large patch washer, by adjusting the nuts I can move the
patch washer up and down the rod, the washer then uses the slave cylinder casting as a stop.
One beauty is you can do it one handed down the footwell. I know there is no rubber on the slave but I will pop a bit of brake grease around it to
keep the damp out,
Steve,
[Edited on 7/4/07 by stevec]
OX
posted on 7/4/07 at 04:13 PM |
good idea.
i'd try and find a rubber boot to fit your clutch and brake cylinders,i got a stone trapped in mine which kept the brakes on,it would of been
pants if it had done it on the road
stevec
posted on 7/4/07 at 06:16 PM |
Good point I wiil dream something up.
Steve.
