New Topic New Reply
Author: Subject: Rear Diff Fitting
LBMEFM
posted on 15/4/07 at 07:43 PM Reply With Quote
Rear Diff Fitting
Hi
I have tried to fit the rear diff today but I cannot get the long bolt in the top hole as it jams against the the chassis. Is the answer to use two shorter bolts either side?
Regards
Barry
stevec
posted on 15/4/07 at 07:45 PM Reply With Quote
Yes use two 12mm cap heads.
Thats what the build manual says but it is worded a lttle un clearly.
Steve.
ReMan
Yes.
I used two large socket cap (allen) headed bolts, the head fits inside the large upper mounting hole
ReMan
stevec
posted on 15/4/07 at 08:19 PM Reply With Quote
New Topic New Reply
